[In arrivo] Lo Hobbit: un Viaggio Inaspettato (2012) di Peter Jackson
Moderatori: nocciolo, darkglobe
- collezionista
Sembra che per la regia del tanto atteso Hobbit alla regia ci sarà Del Toro
Del Toro doubles up for 'Hobbit'
By Borys Kit
Jan 28, 2008
Guillermo del Toro is in talks to direct back-to-back installments of J.R.R. Tolkien's "The Hobbit," which is being co-financed by New Line and MGM.
Del Toro's name was on a short list of directors who could tackle the project, one of the most anticipated literary adaptations of the past decade. An ill-chosen director for "Hobbit" could put billions of dollars at stake for New Line and MGM and could turn off an audience that encompasses millions of passionate readers, Tolkien fans and obsessive geeks.
Few filmmakers have the cachet that del Toro has, as well as a deep love for the source material, an assured grasp of fantasy filmmaking and an understanding and command of geek culture as well as its respect. Del Toro has built that goodwill through such films as the Oscar-nominated "Pan's Labyrinth," "Hellboy," "Blade 2" (which was made by New Line) and "The Devil's Backbone."
For New Line, making "Hobbit" had become a priority in the wake of its billion-dollar success of the Oscar-winning "The Lord of the Rings" movies, which were co-written and directed by Peter Jackson. Jackson wanted to adapt "Hobbit," but when he got into a dispute with the studio over profit participation, the project went into limbo; neither New Line nor MGM, both rights-holders to the film, wanted to risk alienating fans of the trilogy by making an adaptation that didn't have Jackson's involvement.
The December resolution of the Jackson suit, facilitated by MGM CEO Harry Sloan, paved the way for "Hobbit" to get back on the road to the screen. However, because of other commitments that included "The Lovely Bones" and "Tintin," Jackson could not take on writing and directing roles, opting instead to become an executive producer with approval over creative elements of the pair of films.
Because of the strike, no writer has been hired to adapt Tolkien's children's classic, though that process will be fast-tracked once it's resolved. Del Toro and Jackson will oversee "Hobbit's" writing.
Principal photography for the films, which will be shot simultaneously, is tentatively set for 2009. The production budget is estimated at $150 million per film. The release of the first film is slated for 2010 and the second in 2011.
"Hobbit," which Tolkien initially wrote for his children, was published in the U.K. in 1937 to wide acclaim. It centered on Bilbo Baggins, a hobbit who joins a group of dwarves and the wizard Gandalf on a quest to find the treasure of a dragon named Smaug. Tolkien went on to write "The Lord of the Rings" 17 years later.
Del Toro is putting the finishing touches on Universal's summer release "Hellboy 2: The Golden Army" and recently produced the critically acclaimed ghost story "The Orphanage." He is repped by Endeavor and Exile Entertainment.
By Borys Kit
Jan 28, 2008
Ultima modifica di rick_13 il domenica 29 gennaio 2012, 16:56, modificato 1 volta in totale.
Motivazione: titolo corretto
- collezionista
- Glorfindel
- Glorfindel
hummm non credo marv...i film usciranno nel 2010/2011...per Del Toro si preannuncia un periodo di pieno lavoro...
- vegeta85
nel 2009 dovrebbe dirigere "Le Montagne della Follia" dal capolavoro di Lovecraft...secondo me è assolutamente perfetto per questo tipo di film.Marv ha scritto:Porca paletta... speriamo che riesca a fare anche altro.
Certo che ha un agenda fittissima di impegni per i prossimi 3 anni...oltre a questi film c'è in cantiere anche il terzo capitolo della "trilogia messicana" iniziata con "La Spina del Diavolo".
Un progetto più ghiotto dell'altro comunque!
I could live without so much
I can die without a clue
Sun keeps risin' in the west
- Glorfindel
devo dire che un pò mi dispiace che non sia Jackson ad occuparsi in prima persona della regia dei 2 film...comunque sia ora che il regista è stato scelto, la mia curiosità si sposta sul contenuto dei due film.
le strade possibili erano 2:
1: I° FILM -> L'Hobbit; II° FILM -> svariato materiale ripreso dai diversi libri di Tolkien
2: L'Hobbit (assieme ad altro materiale) sarà diviso in 2 film.
sinceramente non so cosa preferirei...
senza dimenticare Hellboy 3... mannaggia!vegeta85 ha scritto:nel 2009 dovrebbe dirigere "Le Montagne della Follia" dal capolavoro di Lovecraft...secondo me è assolutamente perfetto per questo tipo di film.Marv ha scritto:Porca paletta... speriamo che riesca a fare anche altro.
- Glorfindel
ma che ci frega di Hellboy 3
- collezionista
Invece a me Hellboy 3 stuzzica parecchio, ma ci sono tutti i tempi per realizzarlo, visto che tra il primo ed il II ha fatto passare più di 4 anni
Felice per Del Toro regista Hobbit. è sicuramente una garanzia!
- kuso
Io invece sono contento che non sia Jackson a dirigere LO HOBBIT.
La sua visione della Terra Di Mezzo ormai è nota a tutti. Credo che avendo rodato ormai il suo stile, avrebbe portato poche innovazioni.
Con Del Toro avremo sicuramente un altro punto di vista. Un altro modo di vedere le cose.
In questo particolare frangente (Del Toro alla regia) non rimpiango minimamente Jackson.
Penso esattamente l'opposto di quello che non direi se fosse l'esatto contrario di ciò che voglio.
- collezionista
Hellboy ha scritto:Mica troppo, Ron Pearlman ha quasi 60 anni. Se deve fare Hb3 senza far troppo ridere dovrebbero darsi una mossa
Ciao
per avere 60 anni, se li porta bene e comunque rimane perfetto nel ruolo di Hellboy
- Elim Garak
Confermato Del Toro alla regia dei due Hobbit.
http://www.darkhorizons.com/news08/080128h.php
300 milioni di dollari di budget complessivo.
I due film saranno girati contemporaneamente nel 2009.
Uscite previste: 2010 e 2011.
Del Toro e Jackson supervisioneranno la sceneggiatura.
Ciao e a presto!
http://www.kimonoflaminia.it
sono perfettamente in linea.kuso ha scritto:Io invece sono contento che non sia Jackson a dirigere LO HOBBIT.
inoltre c'è da dire che se la regia di jackson ha senz'altro soddisfatto i palati di molti adoratori della trilogia di carta, certamente per 'the hobbit' la 'visionarietà' di del toro dovrebbe rendere ancora più saporito il passaggio dal libro allo schermo.
i miei complimenti a new line e mgm per la scelta.
- hicks82
In attesa del film, mi recupero il libro visto che mi manca...!
Devo tenermi la mia angoscia. La devo proteggere. Perche' mi serve: mi mantiene scattante, reattivo, come devo essere.
Al Pacino in Heat di Micheal Mann
DeathstreetboyZ FB page --> https://www.facebook.com/groups/100156690494/
Mio album 500px --> http://500px.com/AntonioGiampaolo
Mio album Flickr --> http://www.flickr.com/photos/Jamp82
- Folken
decisamente, sarà un periodo di fuoco per del toro con tutti 'sti film (e che film )vegeta85 ha scritto:bè, ottima scelta a mio parere...decisamente un progetto più nelle corde di Del Toro che di Raimi.
Non incoraggiare un uomo perchè ha commesso un solo errore equivale a impedirgli di migliorarsi...
...Mi faccio suo garante perchè un tempo ha sbagliato. non si può accordare fiducia a chi non ha mai commesso errori.
Hagakure (I,50)
- Glorfindel
- rmontaruli
Mannaggia!
Sempre per meschine questioni di soldi.
Io non capisco. C'e' un mondo intero che sta implorando che venga girato questo film e quelli stanno a discutere per pochi dollari.
Che schifo che mi fa questo aspetto del mondo del cinema.
ATTENZIONE!
